book collections email follower instructable user
Picture of 2-Handle Hydraulic Arm Controller
Plywood Hydraulic Arm with Two Control Handles
I was so impressed with the cardboard hydraulic arm by Technovation
(https://www.instructables.com/id/CARDBOARD-Robotic-Hydraulic-Arm/) that I built one of my own from plywood, with some small modifications:
  • I wanted to have more grip on the arms, so I moved the pivot point. (see photos)
  • To get neater and stronger linking wires, I used bicycle spokes. Disadvantage: they are very strong, and small bending errors cause the arms not to meet in the middle. - Note that I had to bend one of them to make the arms meet.
  • I used a round base and disc shaped retainers on the ends of the bamboo skewers to hold them in.
I won't re-hash this construction, as it was very well covered in the instructable.
I have seen other versions of hydraulic arms with 4 controller handles, but I wanted one where the operator could have their hands on both handles and control the 4 functions of raising & lowering, slewing & grabbing without the need to let go of the handles.
Up & down movements are controlled by pushing the handles back and forwards
The grabber is engaged by a sliding pull-up handle within the left controller
Slewing left and right is done by see-sawing the control handles left and right.
I have attached a video of it working:
Step 1: MATERIALS AND TOOLS:
Bill of Materials:
7mm plywood 300 x 300 mm
Wood: ( I used radiata pine)
1 x 15mm x 115 x 70mm
2 x 20 x 40 x 140mm
1 x 20 x 40 x 63mm
1 x 30 x 65 x 100mm
2 x 30 x 45 x 60
1 x 16mm dowel x 135mm
1 x 16mm dowel x 260mm
2 x 16mm dowel x 60mm
1 x 16mm dowel x 59mm
8 x 10cc syringe bodies. On Ebay 6 for $1.39(us)
2 metres of Aquarium air tube
1 x bicycle spoke (U- connector on the moving handle)
Screws, panel pins, PVA wood glue
2 x Rubber bands,
4 x 2.5mm bamboo skewers.
Nails, screws, pva glue.
Essential Tools:
Hammer
Saw
screwdriver(s)
Ruler
Drill & bits up to 25mm
Side cutters, pliers, vice
Files/rasps (round and square)
Sandpaper
Extra tools (make the job easier)
Drill Press
Hole saw with 5/32 centre drill
Band Saw
Coping saw
