book collections email follower instructable user
There are several Instructables showing how to make a stand for a woodworking hand held belt sanders but I haven't seen any using them on metal.
I like to make motorcycle parts 'shiny', it looks better and also makes thing's easier to keep clean
I'll show you how to polish small parts to mirror finish using far less work than files, emery cloth, etc. I had been doing these parts by hand but it took quite a long time to get good results, this method gets a better finish in about 20 minutes
Things you need :-
1. hand held belt sander - mine is a real cheap one from Harbor Freight Tools, made in China and available pretty much everywhere although the name may be changed in different countries - I know it is in Canada and Australia
2. Vice or some method to mount sander 'upside down', could always search for Instructable on mount
3. Dust mask - very very important, aluminium dust is believed to cause long term health issues, Alzheimer disease, etc
4. Heavy gloves, two reasons, you are quite likely to accidentally touch belt and the parts will get quite warm through friction
5. Face shield or goggles, this is pretty dirty, I used a micro fiber cloth to clean it up
Final pic is sander 'mounted' in vice using the front handle
I messed up a bit and put this into introduction instead of first step, I'll get better at it eventually
Step 1: The component to 'shine up'
Picture of The component to 'shine up'
Carburettor mounting bracket for 1974 Honda CB360, mould line and sharp edges
start with an 80 grit sanding belt. when the seam has been ground off, switch to 120 grit belt to remove scratches from 80 grit
Now that's one way to get things shiny...!
