book collections email follower instructable user
Hi everyone! Thanks for tuning in to this project of mine, I hope you'll like it and perhaps try to build it yourself! As always I have included a detailed list of modified plans, a wiring diagram, product links and much more for your information on the build. I encourage you to check my video first before diving in to the build. Let's get started!
Step 1: Design Goals and Plans
Picture of Design Goals and Plans
The main goal for this project was to build a subwoofer that would play pretty low and would have an integrated amplifier capable of powering two other speakers all cramped inside a relatively compact enclosure. Fiddling around with various woofers in winISD I have decided to go with a Tang Band woofer and a 2.1 amplifier for best results. As you can see by the graph, the enclosure is tuned to 43Hz and has an F3 of around 37Hz which is pretty amazing considering the price of the woofer and the compact enclosure that it needs. Of course it will not play that low cleanly due to port noise and possible chuffing but will still perform great.
As you can see below, I have attached a set of plans, metric and imperial for all needs. You will also find the template for the control panel in the end of the plans which you can print out and glue to a piece of wood to have an accurately made control panel. Feel free to download the plans and the wiring diagram for your personal use. I would love to see how your project turned out!
Note that I have modified the plans therefore the speaker may look different than in the video. I have modified the plans to use less components and be easier to build with an overall better design.
AarmitB8 days ago
Hi Donny I want to this product
suksusu2 months ago
nice work and thanks for the drawing
MERCY LANA3 months ago
wow i must try this thank you
James Brock4 months ago
Great job, Thanks! Really good stuff!
Add a power-saving sleep-mode circuit that will auto-sleep after 10 mins (or ?) of inactivity while using a very small power to listen for audio I/P signal to power-on the sub back to life. Very professional and impressive wood-work too!
Donny Terek (author)  jagmeet_hanspal4 months ago
Thank you for the tip! I might look into that.
FrancescoD524 months ago
what is the program in step 1?
Donny Terek (author)  FrancescoD524 months ago
Sketchup!
Steve Dallman4 months ago
Great project. I think I'd look for a more efficient sub, although all the other specs, especially Xmax look great.
Donny Terek (author)  Steve Dallman4 months ago
Thank you! I chose this sub to be able to use it in a small enclosure producing great results.
audreyobscura4 months ago
Thanks for your thorough documentation!
Donny Terek (author)  audreyobscura4 months ago
My pleasure as always!
coltdog4 months ago
Great job! Thanks for sharing the tips and tricks that take a build to the next level!
Donny Terek (author)  coltdog4 months ago
Thank you so much!
Roy L Miller4 months ago
Hi, what a great looking project with a nice clear set of build instructions.
Can you please explain ,what is the purpose of the ports and the piece of pvc pipe? is it for ventilation? Thanks for a great job!
Donny Terek (author)  Roy L Miller4 months ago
Hi, thank you so much!
The purpose of the ports used in many speakers is to improve the efficiency of the low frequencies produced by the speaker. Generally speaking, it helps most speakers play into lower frequencies. The length and width of the port needs to be calculated according to the speaker used in the enclosure.
I hope that answers your question!
Robbo_roberto4 months ago
NICE WORK!!!
Donny Terek (author)  Robbo_roberto4 months ago
Thank you!!
TomL2324 months ago
Very nice project!
From your building skills to your video production and presentation, you seem to have a very disciplined and methodical approach to everything you do and it shows. Well done!
Donny Terek (author)  TomL2324 months ago
Thank you so much! That truly means a lot to me :)
