book collections email follower instructable user
Hi everyone! In this Instructable I’m going to show you how I made a tree ring shaped wall clock.
I made this clock to celebrate my first anniversary on YouTube.
Materials:
Plywood - 21 mm thick (your local hardware store)
Clock mechanism http://amzn.to/2pswt4Z
Colored pencils http://amzn.to/2GNEtG0
Clear fast-drying polyurethane http://amzn.to/2pr3PBM
D-ring hanger http://amzn.to/2psvtxL
Tools:
Jigsaw http://amzn.to/2pqpJFl
Router http://amzn.to/2HRqxtU
Cordless drill http://amzn.to/2FTtiKn
Dremel high performance rotary tool kit https://amzn.to/2E873Ay
Forstner drill bits http://amzn.to/2HPeI7e
Router bits http://amzn.to/2G8091l
Sanding block http://amzn.to/2IDpQVW
Let's get started!
Step 1: Making the Shape of the Clock.
This clock is made out of 21 mm thick plywood. This large plywood board is pretty heavy, so I cut it 60 by 40, which will make the drawing of the shape easier and faster.
Now, I can start drawing the shape of the clock. I wanted to make a tree ring shape, and I hope I achieved the goal.
In the beginning I drew total of 6 rings, with a nice transition between them. Actually, my plan was to make each ring a different layer, and all of them to be 3 mm high, only the smallest one to be 6 mm high. Later, I realized that I needed to make 7 rings, all with 3 mm height, which will improve the look of the clock.
But, let’s go back to the shape. Once I was done drawing, I cut with a jigsaw, following the outline of the largest layer. So, I got the final size of the clock, which is 55 by 35 cm.
snowf71 year ago
I think it looks great. I love the rustic feel you get from it. It is very eye-catching and also easy to read. Great job!!!
I think it would look nice if you sanded the edges smooth, instead of having step-up edges.
