book collections email follower instructable user
Picture of Flamethrowing Jack-O'-Lantern
A flamethrowing jack-o'-lantern keeps the trick-or-treaters a safe distance from your house and is a fine addition to any anti-Halloween arsenal. At the first sign of any sugar-obsessed imp, simply press the trigger button and wirelessly shoot a one-second burst of flames out of the jack-o'-lantern's mouth. This plume of hellfire will make even the most bold of people think twice about approaching your door. Very few people are willing to risk life and limb for the chance of a tiny box of milk duds.
WARNING!: This pumpkin is extremely dangerous and you definitely should not make one of these. The instructions were posted here are for entertainment purposes only. I do not condone the manufacture or use of flamethrowing jack-o'-lanterns. Seriously, nothing good will come of making one of these. Don't do it.
Step 1: Go Get Stuff
Picture of Go Get Stuff
For carving the jack-o'-lantern, you will need:
- A large pumpkin (mine was probably about 18" in diameter)
- An assortment of cutting knives. Serrated seemed to work the best.
- A marker
- Paper and pencil
- Scissors
- A spoon
- Other scraping implements. I found a chisel worked very well.
For the remote controlled flamethrower:
- Door lock actuator
- SquidBee transmitter and receiver. I had these lying around from a previous project. Any Arduino/Xbee combination should do.
- An extra ATMEGA168 or ATMEGA28 (only if using the Squidbee setup above as the receiver has no chip)
- Small can of WD-40
- 12" x 12" x 1/8" sheet of black acrylic
- SPST 5V relay
- Perfboard
- 5" x 2.5" x 2" project box.
- SPST momentary pushbutton switch
- 10K resistor
- (x2) 9V battery snap
- (x2) M-type plug adapters
- Misc. long zip ties
- 16" x 2" x 1/4" aluminum extrusion
- 3-1/2" x 1/4 bolts
- (x6) 1/4 nuts
- Tea light
- Matches
AnthonyH192 years ago
So the Door Lock Actuator spec is to 12V. Does this work well with the 9V supply?
randofo (author)  AnthonyH192 years ago
I don't know, but it likely should still work with 9V.
nearboston2 years ago
Since no one is going to build this I don't have to tell you not to swap out a can of engine starting spray (ether) for the WD-40. That would make a flame that is much more dangerous. DON'T DO IT!
Haha lol, what about carburetor cleaner? :D
Apxeon5 years ago
OMG your porch is made of wood though!
Wood isn't as flammable as most people think.
That's probably why they make wood stoves.
WildB allangee2 years ago
That's not how combustion works. To catch an object on fire, it has to be brought up to its ignition temperature for a long enough period of time to get that self sustaining reaction going.
A momentary burst of fire, unless the object has a very low ignition temperature, usually does not set things on fire. Most wood has an ignition temperature of 190-260°C - even decayed wood needs 150°C to ignite.
The flash point for WD40 is 49°C, which a tea light candle burns at a maximum of 1400°C - as you can see, it easily reaches the WD40s flash point for ignition. Once the hydrocarbons in the WD40 reaches flashpoint, they leave almost no residue of the fine particulates due to their aerosolized nature.
You might get some flash charring, but even that is likely with maintained wood.
allangee WildB2 years ago
Which, as I said, is why they can make stoves out of wood.
AlecM7 allangee2 years ago
Can you post a link to a picture of a wood stove?
allangee AlecM72 years ago
Here's a closeup shot.
I don't see it
I went on the hunch you were being sarcastic, which is why the post explaining things.
Kids wearing sheets are though...
valkgurl DougZ12 years ago
Hows about you keep those KlanKids out of the line of fire then?
BarryN22 years ago
I am waiting now for someone to build this, and then next some lawyer to file suit against this web site for posting these instructions after someone gets hurt. I have no doubt that some idiot will will build this and misuse it and someone somewhere is going to get hurt. It is not a case of if, it's a matter of when.
holla20402 years ago
Classic!
GordonW162 years ago
If you know that this is "potentially" dangerous, why post it?
To say that it is for "entertainment" only... There are enough idiots out there (check out Youtube or America's "Funniest" Videos) that will be sure to try this at home... Just my opinion. Happy Halloween!
rxima3 years ago
hahaha good idea
Darzen3 years ago
Nothing good will come except: Watching little children running around with smoke coming off of them like when Mario touches fire in Super Mario 64!
lime3D4 years ago
The WD40 formula has changed, and will no longer work for this. You might be able to find aerosol hair spray.
Ether will work
won't be better to put a spark generator in the pumpkin rather than candle?
Hmmm - bringing tricks back to Halloween. I laughed my ass off the second I saw this one!! I agree it's a bit... extreme but what a cool idea!!
I made something very similar to this last halloween. I removed the pump mechanism from an electric weed sprayer, and secured it inside a jack o lantern. I also connected a gas tank of lighter fluid to the back of the pumpkin, and extended the battery pack by about ten feet and inside my house. I then placed an ordinary candle inside the jack o lantern, and sprayed flame by activating the pump from inside the house. Not exactly wireless, but you couldn't tell how it was powered.
The neat thing about this design was that the tank could be filled with any oother liquid such as water or fake blood. The effect was pretty cool.
Thanks for inspiring me. And i try this!
We don't have the same nanny-restricted worldview as you. People have an innate right not to be messed with, and there IS an extensive warning about the danger of the project at the beginning. Get a grip on yourself. Sheep would be more like you, hating everything that you don't condone.
I don't think you know the definition of "creative.," because that was very much destructive. And who made you judge of the project's utility? Don't like it, move along.
Mr.5 years ago
This is great and I'm sure you'll use it safely but pleases remember that many Halloween costumes are very flammable and you will seriously injure someone if you light them on fire.
kjlpdx5 years ago
easiest would be a wire and switch assuming you're smart enough not to want to fire this without being present and watching. also no stray signals could set it off.
astral_mage6 years ago
easier idea is use 1 of those motion censored air freshners. but angle the tube down ward. an out the front over the candle. uill get the same result. w/o going thro the same programing stuff
wusupworld6 years ago
to late making it hahahahah take that kids who trash my house i'l use a tripwire hahaah
dennist16 years ago
With arduino and a distance sensor, this could make quite a security system! Don't try this at home or anywhere else though - the idea would make this even more dangerous than it already is!
dennist16 years ago
Neat idea, for sure ... but Arduino is a bit overkill. All ya gotta do is power up the actuator. Even real fancy, use a 555 and the relay to limit the on time (to save baking the pumpkin).
baited6 years ago
This is a cool project. You may want to place a diode across the coil on the relay to protect the electronics. And depending on the relay a transistor may be needed to handle the current.
JensonBut6 years ago
I'm rating most of your i'bles 5! Awesome stuff, affordable and compact.
awesome! i wish i had known about this far enough in advance of october 31st to construct it. seems a fairly simple idea just having a remote controllled aerosol can to spray over a flame. i would like to know if there is an easier and cheaper way to set up a remote control system for other projects, i do not have an arduino but surely i can make a transmitter/receiver from basic electronic components or rewiring a remote control car.
RC car would be my suggestion.
mangomango7 years ago
I'm working on my own creation for this halloween and i was wondering if you had problems with your candle getting blown out?
I don't think they actually made this, remember?
1-40 of 111Next »
