book collections email follower instructable user
Step 12: The Sweet Soft Tubularisation
Picture of The Sweet Soft Tubularisation
The maximal diameter of your canoe is equal to the smallest diameter in your log, and obviously most of times the crown side has the last word.
In my case, that zone whith the crappy fork. Of course I could have made it all easier by cutting that end. Problem was that I needed that sufficient length very badly in order to maintain future canoe stability. It was going to be a sea canoe, so I needed every extra inch I could grab. 1 to 8. For every inch diameter you need 8 inches length.
Finally I ended up with a diameter of 45cm. I cut two plywood discs, screwed them to each side and started shaping that cilinder into perfection. Some zones got nearly planed, others went deep in the sapwood.
