book collections email follower instructable user
Step 19: The Obsessive Symmetry Complex
If I would do it again, I'll thrust more my axes and less my power plane.
I'm an axe man now. But I'll never forget what you did to me, dear power plane.
Using an electric plane has the advantage that it doesn't need any skills whatsoever. If there's power, there'll be chips. And it helps to conserve smooth lines. The length of a plane is an often underistameted feature. Especially to carve the bow a longer plane helps substantially to carve the right path, the way water will be deviated from the vessel.
I will do it again, this whole thing. But I'll give you my power plane as a present, anyway. You can do the whole instructable with one axe, technically. Two axes is better. And an adze, a gouge, a drawknife and a scraper. You really don't need them, these power tools.
Whatever. Shape one side of the canoe first. Finish it completely before you move to the other. It's all about symmetry. A canoe that isn't symmetrical will haunt you till your last breath. And it will turn in circles forever, also.
Shape is a personal issue. Remember your vessel has to penetrate the water and move it sideways. Shape the nose like a dolphin crossbred with a plow. I chose the length of the nose/bow to be twice the diameter of the canoe.
Sounded acceptable.
