book collections email follower instructable user
Step 4: Cut and Glue the Dowels
Picture of Cut and Glue the Dowels
The dowels will both be used to hold the piece in the drill, and later in the process will be cut shorter to form a tenon for installing into the final piece.
Mark and cut the dowels to between 1 3/4 and 2 inches. Don't skimp here, as you'll want your drill to have a good grip on the dowel. If the pull ends up sticking too far out of your drill, you can always cut the dowel a little shorter.
Using super glue or wood glue, glue the dowels into the pulls. I used a mallet to make sure they were seated well. If you end up using super glue, using CA activator will set the glue faster so you can keep working.
