book collections email follower instructable user
Step 6: Attach Runners
Picture of Attach Runners
Use washers or pennies under the runners in the table saw tracks to lift the runners just barely above the surface of the table saw. Apply CA glue to the runners and set the base ply on at a 45-degree angle with one corner directly in the path of the table saw blade. Do your best to make it 45 degrees but perfection is not required.
Allow the glue to set up and remove the sled from the saw. From the underside, pilot drill, countersink, and install wood screws to permanently attach the runners. Trim excess material after attachment. See video in the introduction if this isn't clear.
