book collections email follower instructable user
Multi Purpose Rotary Machine - Mulling, Welding, Pottery, Photography Turntable
FeaturedContest Winner
Step 21: Motor Control #7 - Components List & Acquisition Notes
Picture of Motor Control #7 - Components List & Acquisition Notes
When I make a project like this I get a lot of the components from old circuit boards. Although individually cheap they add up in cost, and waiting for delivery is a pain.
To de-solder lots of them QUICK I use a hot air gun and pliers - it's not gentle and I wouldn't recommend it for things you really care about (it can overheat components) but it's effective! The exception to this is resistors! They are used so often, and are so cheap that having a stack of new ones of known values saves a huge amount of time. I still salvage and use power resistors (1W and up) though.
To use capacitors that you salvage, put them in parallel (simply add capacitance together) to make up the required cap value (two or more capacitors in parallel is usually better that one higher value cap anyway).
The codes below refer to the schematic by Saulius Bandzevičius on step 17 (when I get the time I will draw out the schematic of the circuit I actually ended up creating, but this is very close)
I used Perfboard to mount the components - I still think its the best way to make one off prototypes you plan to put to use!
R1 3k3 (for all the resistors apart from R14 consider getting a 1/4W resistor pack like this - it's too much work to salvage loads of small resistors, and once you have a pack it will last you for lots of projects)
R2 2k2
R3 4k7
R4 470
R5 100k
R6 10k
R7 30k 0.5W
R8 30k 0.5W
R9 10k
R10 1k
R11 360
R12 360
R13 470
R14 100 5W
C1 220nF (salvage all caps if you can - they add up in cost quickly and are easy to salvage)
C2 100nF
C3 47nF 600V
C4 100nF 600V
C5 3300uF 10V
C6 100nF
D1 1N5817 schottky diode
D2 Any full diode bridge 400Vmin.
D3 1N4007 diode
D4 BTA26 (although BTA16 is enough for this motor)
Q1 S8050 or any npn switching transistor from 0.7A and 20V
U1 LM393 - Datasheet http://www.ti.com/lit/ds/symlink/lm393.pdf and application notes http://www.ti.com/lit/an/snoaa35/snoaa35.pdf
U2 PC817 Optocoupler
U3 MOC3023 Optocoupler
U4 Arduino Nano V3 complete board
PS1 Any suitable 5V power supply.I used an old mobile phone charger
F1 6-10A fuse F2 0.5A fuse
K1 Any 5V relay with 10A/250V contacts
SW1 Dual 10A 250V switch with indication lamp
SW2 Rotary encoder with push button
SW3 3 positions switch
16x2 HD44780 LCD display with I2C serial interface module
