book collections email follower instructable user
Picture of Super Stuck Two Stroke Cylinder - 47yrs?
I've been attempting to 'Resto-Mod' a 1968 Suzuki T305 for a friend. for about 18months.
When I got it started it had much louder than the 'normal' two stroke rattle and ring, probably worn piston rings or cylinders which means the 'top end' has to come apart for inspection.
The right side was very tight to remove, one cylinder stud was stuck pretty good in the hole in cylinder
The cylinders probably haven't been removed since it was built in 1968.
The odometer reads almost 16,000 miles which many people will feel is very low but anyone with experience of 'high performance' two strokes will know is actually quite high miles for minimal servicing.
The service interval is variable depending on use, high rpm will wear things out much faster than mid range operation.
Step 1: The Offending Parts - Explanation With the 'easy' Cylinder
Picture of The Offending Parts - Explanation With the 'easy' Cylinder
The problem is relatively easy to describe but the solution has been very difficult (and is still 'in progress)
The cylinders have holes through which are a relatively close fit on 8mm studs. As majority will know, aluminium likes to oxidise and form a white 'fluffy' coating. Unfortunately, when there isn't room for it to expand, it grips so tight onto 'stuff' it's almost welded. I kinda documented the steps so far in attempt to remove cylinder from crankcase WITHOUT DAMAGING ANYTHING
The first thing to do was the common, fill with release oil and wait 24 hrs. Well, I waited about 2 months (or more, Chris wasn't in too much of a rush) testing every day or so , not even the slightest movement. After 6 months it was getting ridiculous and frustrating.
crazypj (author) 3 years ago
The Muriatic acid did a lot of fizzing but doesn't seem to have done any good to release cylinder. It has however, 'removed' most of the threads in holes. Probably have to step up to inch size or 16mm. I may just make a drill guide and drill out studs, (that is the final solution)
lomnicks4 years ago
Hi, I am an ex-zuke mechanic and have worked on these. Reset the base gasket and drop muriatic acid into the bores. suck out and repeat until it lets go. good luck and btw the carb slides are not the same on each side, so if you have removed them and put it back together and it runs funky, try switching the carb slides back. They look nearly identical but they aren't. I spent a lot of time figuring that one out. And you are right -16k is a ton of miles on one of these.
crazypj (author)  lomnicks4 years ago
Hi Tom, I was also in a Suzuki/BMW/Vespa/Yamaha dealer for a number of years, ended up running the workshops until 1990.(prior to that was at Honda/Yamaha dealers)
I know about the carb slides, Yamaha did the same thing (we seemed to get a lot more Yam's with slides in wrong carbs) I never even thought about muriatic acid, I have some here from experimenting with DIY circuit boards (muriatic acid and Peroxide -works well) I'll be trying it later as one stud is still 'stuck' At least 3 let go though -LOL
