book collections email follower instructable user
Step 15: The Chatterbox - Part 3 - Setting the Audio Clip Addresses
Picture of The Chatterbox - Part 3 - Setting the Audio Clip Addresses
The audio clips are stored in a continuous block of memory on the KA02 from address 0x010 to 0x2DF as shown in the diagram. It is necessary to determine the start and end addresses of each clip.
The example KA02 sketch downloaded from www.velleman.be was adapted to allow each of the 14 audio clips to be played. The resulting ino file is attached.
The addresses are determined as follows:
The KA02 / UNO R3 is connected via a USB lead to a PC running Arduino.
1. The sketch is uploaded to the UNO R3.
2. In the Arduino Serial Monitor type 1 and press enter.
3. The first audio clip should play. Note if the whole clip and nothing else is played.
4. If not, adjust the start and end addresses of the first clip in the sketch (lines 14 and 15), upload the modified sketch to the UNO R3 and go back to step 2.
5. If all is OK, continue to the next step.
6. In the Arduino Serial Monitor type 2 and press enter.
7. The second audio clip should play. Note if the whole clip and nothing else is played.
8. If not, adjust the start and end addresses of the second clip in the sketch (lines 18 and 19), upload the modified sketch to the UNO R3 and go back to step 6.
9. If all is OK, continue to the next step.
Repeat this process until the addresses for clip 9 have been set.
For clips 10 to 14, instead of typing a number into the monitor, use the letters a to e.
