book collections email follower instructable user
Step 6: Assembly of Diorama Base and Surfboard
We designed a plug-in board underneath the wave box, in order to elevate the system. Supports can be plugged into the base plate in x and y direction to carry the wave box and the motor. The base can be assembled according to the pictures from the previosly cut plexiglass, gears, bolts, washers, nuts, aluminium sleeve and the servomotor. Make sure to stagger the gears and transfer the load of the water-filled box not directly on the servo-motor. The wavebox is not firmly attached to the base. It lies on an aluminium bolt (the tilt axis of the whole construction) and is only held in place by narrow plexi slices. The tilt axis of the construction is arranged asymmetrically in order to guide its movement and to prevent the box from falling down.
